davecool
Re: BV6300 PRO UPDATE issue
Sat Jun 05, 2021 4:46 am
Hi, can you answer if there will be a BV6300 pro update for your phone. You said maybe in January. It's been almost half a year. You make good phones but the support is poor.
davecool
Mon Jun 07, 2021 5:12 pm
BV6300Pro_EEA_TE988_V1.0_20200708V14 It's on the phone now. Is this an OTA update. Can you send OTA as an update.
Jose.t
Tue Jun 08, 2021 8:02 am
how is it done? do I download to internal memory or to SD? is updated from android menu or from bootloader?
Jose.t
Wed Jun 09, 2021 7:02 pm
To update should I use sp_flash_tool_v5.1924?
Or the aftersale tool?
Users browsing this forum: TimothyLal and 3 guests
