Re: Fresh A5 ROM in July
Wed Aug 03, 2016 7:16 am
smarthousesys wrote:
Hi
Do both the ROM A and ROM B links actually access identical files. SInce the names are the same and the name has HD in it I assume
is for the NEW screen A5 version . I have the original A5 screen 480x854(bought in May).
Regards
yes , it is for the higher screen resolution one.
Best regards,
Admin
kireerik
Wed Aug 03, 2016 7:59 am
Can you add update for the device with the lower screen resolution as well?
Thank you for your assistance in advance!
smarthousesys
Wed Aug 03, 2016 3:52 pm
Hi
Are you saying there is no update available for the original A5 screen format.
It would have been better if that had been made clear in the post about the July a5 firmware update.
Regards
Hi
Regards
Best regards,
Admin
Thu Aug 04, 2016 7:15 am
Hi
Regards
Hi
Regards
Best regards,
Admin
Thanks for your advide, yes we will make it clear in the post.
Best regards,
Admin
Thu Aug 04, 2016 7:20 am
I will ask software engineer if they have any update.
Best regards,
Admin
Thu Aug 04, 2016 7:23 am
rebecca wrote:
I have 854x480 screen, which rom to use
These roms are not suitable for your device. They are for higher screen resolution one.
Best regards,
Admin
Fri Aug 05, 2016 7:19 am
Cane wrote:
Will this new ROM be available in OTA update form?
Now still no news about this!
Best regards,
Admin
rebecca
Sun Aug 07, 2016 6:15 pm
Best regards,
Admin
thanks for the explanation. hope you will provide updates for the A5 (both screen resolution) in the future
Cane
Mon Aug 15, 2016 12:01 am
Could you please make these ROMS available as OTA update, so we could avoid confusion about which ROM is suitable for which version of the phone? Thanks in advance .
zsolt
Wed Aug 17, 2016 10:36 pm
The ROM extension is tar.gz, however, the updater needs zip. What should i do?
