ghost82
Re: [SOLVED] Local ROM update not working
Sat Jan 06, 2018 2:48 pm
You can try titanium backup (root and busybox needed), or helium (never tried), if you don't have root.
Chris_2017
Sat Jan 06, 2018 4:15 pm
Just flashed my device and rolled back with google, it all clicked nicely. Thanks for the help admin!
Sat Jan 06, 2018 9:12 pm
You're welcome! ;)
kavedel
Re: Local ROM update not working
Sun Jan 07, 2018 9:07 am
"A phone wipe (aka factory reset) is highly recommended after each update, OTA, local or flashed.
This is a good practice on all the Android phones if you want to avoid issues and to use firmware updates correctly. ;)
Next updates, as always, can also come via OTA, so in this case you won't have to flash your device everytime.[/quote]"
Just a question for the admin, since I never had before an upgradable phone. I flashed it to the latest rom and then installed the OTA upgrade 20171227 both times I did a factory reset. The procedure to reinstall all the apps and reconfigure them is very time consuming. Is it necessary to do factory reset after OTA? You confused me a bit with your previous post.
Sun Jan 07, 2018 9:40 am
A factory reset should be done after every firmware update, OTA included!
To reinstall apps and reconfigure settings, use the stock Google android backup ;)
Chris_2017
Sun Jan 07, 2018 2:55 pm
Isn't that a bit of an overkill? You don't see us wipe our entire computer whenever windows does an update right? ;)
Sun Jan 07, 2018 11:48 pm
I'm repeating myself again and again :twisted: :lol: if you don't perform a factory reset after a firmware update, strange issues may happen. It's proved!
mambociccio
Mon Jan 08, 2018 8:33 am
yes
mambociccio
Mon Jan 08, 2018 8:38 am
Feel a moment please!
There is no need for me to make a factory reset every time!
I had Meizu and it never happened like that!
Do you realize that this situation is embarrassing?
a phone with excellent hardware and a firmware that has continuous problems.
Do you want to solve once and for all?
I use google translate, I hope to make myself understood
Mon Jan 08, 2018 9:10 am
We are continuosly working on it to grant the best user experience we can ;)
Android is a very complex and fragmented OS, it's not a news. Blackview is not the first and will not be the last.
