Jim1986
Re: sim card slot problem contact in omega pro
Sat Jan 09, 2016 8:27 pm
I have the same problem, the sim connections suddenly disappear or disconnecting for few minutes.
Ange
Sun Jan 10, 2016 10:45 am
blackview_admin wrote:
Ange wrote:
pascal wrote:
Hello
my phone worked well four days .
at any time and for no apparent reason ( must contact) I lose my SIM card and my SD card for 1 to 2 seconds . it asks me the PIN and so on
I can not serve me the phone.
This happens by storing my phone in my pocket, in the Tenat in hand, pasant a finger on the slot to enter the SIm card, by calling , having it on a table.
I see that many people have the same concern , you have identified the failure? I hope you will not let a loyal customer BlackView . I really count on you .
thank you for your quick response and your part..bien sérieude to you
Pascal
working.
Hello. Same problem for me, i put a small adhesive ribbon in the on the back of the simcard and SD card and it seems
We feel so sorry to hear your problem about the sim card slot , you can contact the seller first to see any
solution to help you.
Best regards,
Admin
Hi, indeed, the adhesive tape really does not function. The problem persists after this false good solution.
sport_evo
Mon Jan 11, 2016 12:37 pm
Hello.
I have seen the same problem. With and without sd card installed, or With one or two sim installed.
I have tried to take a piece of adhesive ribbon over the sim and have the same problems... it´s not mormal...
Tue Jan 12, 2016 1:51 am
really sorry for your problem.
we have talk about the sellers, you can go to them to ask a new good simcard slot free of charge \.
Any details, you could see from the following web link.
viewtopic.php?f=79&t=2856&p=4670&sid=78451a82ceef254dfdafad996b185f5b#p4670
Sorry again for the problem .
Best regards,
Zandy
Tue Jan 12, 2016 6:28 am
Hi , so sorry for the problem ,
please we have discuss the problem with
sellers , you can go to the shop you buy , and ask the
seller to ship a free sim card slot to you to solve the problems.
Sorry again and hope for your understanding
Best regards,
Admin
haris
Tue Jan 26, 2016 4:06 pm
I'm having the same problem, I've contacted seller and hopefully I'll get a replacement sim slot. If I get into issues, I'll post here. It is so great to see Blackview being so acknowledging and helpful, gives me a lot of trust.
Also I'll like to appreciate the design and quality of this phone, it is amazing for the price. I would wish if Blackview launches a similar model with some more advanced features (FHD screen, finger print sensor, NFC, a bigger battery, compass, gyro) - an Omega 2 may be ?
Tue Feb 23, 2016 7:24 am
Hi ,
In 2016 , we will have lots of good smartphone , worth your expectation .
You will like our R7 !
Best regards,
Admin
GeorgeD
Sat Feb 27, 2016 2:13 am
I am facing the same problem.
The sims are not detecting, suddenly start showing one sims, little later both were not showing & etc. etc.
yes I have asked the seller to send the card slot.
Still I have doubt the card slot will how solve this problem.
Can any one from Balackview explain & if not work after reinstalling the new card slot. what will be the solution. hope BW will understand the customer feelings.
Thanks
Tue Mar 01, 2016 8:12 am
mynz wrote:
Same problem with my phone...
Every few seconds or minutes, my phone finds or looses SDcard, interrupted by PIN-prompting. And all this happens while it's lying on the table.
@support: sending me to a local repair shop is not an option.
Mynz
Have you ever contacted with your seller about the question?
Best regards,
Admin
Dima Smith
Wed Mar 01, 2017 2:44 am
Ok will try that How long time is normal for CA not found repair with recover bad sectors?
