v4l3ru
Lower buttons don't work
Thu Jul 14, 2016 11:13 am
I have a problem with my phone. I used it for 3 months, and it didn't suffer any physical dammage (no shock or water).
The lower buttons (options/home/back) don't work anymore. The touchscreen works perfect at any point, aswell as any function of the phone, with the exception of the three buttons on the bottom.
Can you tell me what the problem might be? And if it can be rezolved without the replacement of the screen?
Thank you,
Andrei
Re: Lower buttons don't work
Sat Jul 16, 2016 7:22 am
Suggest contact your seller to work the warranty.
Best regards,
Admin
