virori
Bluethooth not work on Android 6
Thu May 19, 2016 1:52 pm
Since I upgraded to Android 6 version the Bluethooth has stopped working . Why?
Re: Bluethooth not work on Android 6
Fri May 20, 2016 7:01 am
can you tell me how you get to a upgrade ? via OTA update or flash tool ?
Best regards,
Admin
virori
Sat May 21, 2016 10:57 am
I upgrade to Android 6 via Flash tools
makelued21
Mon May 23, 2016 9:49 am
is your phone can charging?
maneex
Mon May 23, 2016 10:29 am
I think none of those phones which have been uograded to 6.0 are charging normally. Tested with 5 BV5000 and all of those have same problems.
Tue May 24, 2016 6:10 am
we are working out a proper solution. we will release a improved OTA update to help you, please
give us some time and wait patiently.
Thanks!
Best regards,
Admin
virori
Thu May 26, 2016 4:42 pm
Yes, the phone charging without problems. Te problem is the Bluethoot. Don´t conect to bluethoot of my car (ToyotaTouch). Whit the Android 5.1 connect perfect
Users browsing this forum: Google Adsense [Bot] and 11 guests
