ehquionest
Re: How to Root your BV5000
Thu Apr 28, 2016 2:01 pm
It doesn't work for me...
meany
Tue May 03, 2016 12:15 am
Hi SnuffThePunkz,
I can't access that download. Would you be kind enough to put it somewhere else (eg Mega or another file repo)?
Is the root permanent (eg after factory reset)?
SnuffThePunkz
Fri May 13, 2016 1:17 am
Bump for Update visibility.
Pete
Fri May 13, 2016 1:31 am
Sorry for not know the lingo but what do you mean by Bump for Update visibility.[/quote]
SnuffThePunkz
Fri May 13, 2016 1:34 am
Well I updated the main post, and I hope it helps people but it was getting low so I posted which "Bumps" it back up to the top where it is visible.
dabomb
Mon May 16, 2016 2:38 pm
I flashed the latest 1.1 get a clean Android 6 Update. How to root the BV5000 on Android 6?
SnuffThePunkz
Tue May 17, 2016 2:18 pm
I am trying to work that out, new to the Android OS myself. So I'll be doing some reading over the next day or two.
