imbaaalanced
help! simcard-slot doesnt work properly!
Fri Dec 18, 2015 11:46 am
hey dear blackview team,
i've got a problem with my blackview omega pro. if my handy shakes too hard ( for example in my pocket or while using it ), my connection get lost and my mobilephone requires to enter my pin again. when i touch or press the simslot at the upper right side of my mobilephone, it's doing the same. it looks like the simcard-slot doesnt work properly. got some1 else the same problems, or does the support know how to solve that problem?
greets
Re: help! simcard-slot doesnt work properly!
Mon Dec 21, 2015 9:12 am
So sorry to hear you problem.
Because we now can not see your smartphone to see the actual reason, so we can not help you solve the problem directly.
really sorry for that .
But you may can contact the seller to see if they can provide any solution.
Best regards,
Admin
