blackviewmiha
TAB 8 shuts down
Fri Dec 25, 2020 12:32 am
hello,
i just bought a few days ago a TAB 8 and keeps shutting down for no reason.
Even when i`m not on the tablet and it`s on stand by and also when i charge it. I`m using an original charger.
Please advise,
Re: TAB 8 shuts down
Fri Dec 25, 2020 6:41 am
blackviewmiha wrote:
hello,
Please advise,
Can it be turned on again after it is turned off?
blackviewmiha
Sat Dec 26, 2020 11:30 am
yes, it can. But until when i can do that? Besides i have 3 days since i bought it.
Someday it will shutt down and never get restarted again.And then...pufff,no tablet. Money...not well spent.
 I will return it and never buy this brand again, ever.
I wanted it to know why it does that to fix it, not temporally solutions.
Are they all at faulty? i did not want to listen of the reviews,but it seems they were right. :)
please advise
Myrkgard
Mon Jan 04, 2021 11:51 am
Just want to interject that my TAB8 shows the same buggy behavior. Have to press'n'hold Volume-Up and Power to restart it, otherwise it ends in a boot loop. Have already reset it to factory settings but that didn't help. The device is unusable banana ware. When will this get fixed?
P.S.: Sorry for hijacking your thread. Registered 3 days ago and started my own thread but it seems the mod is on holiday.
Tue Jan 05, 2021 7:49 am
please advise
Hey sorry to hear about the issues with your order. May I know where did you purchase it? And have you ever contacted the service to help you solve this problem? In order to solve your problem more effectively, please contact the store you purchased the product straight. Our support team will be in touch to assist you with this. Here is the email: support02@blackview.hk
Tue Jan 05, 2021 8:07 am
please advise
Hello, we’re so sorry you’ve had a negative experience. You can contact the store to change one or refund the money.
Tue Jan 05, 2021 8:34 am
Hello, sorry to hear about the issues on your order, can you try to flash the product to see whether it can work or not?
Tue Jan 05, 2021 9:36 am
These is the operating instructions and tools. To power off and plug in the tablet, long-press the volume down button when the tablet is plugged in, and then plug in the data cable to upgrade, here is the link: https://mega.nz/folder/ra4CGawT#ygurrUkkE1b95mzj9KkvXg
https://mega.nz/file/WKoGRCLY#0UnN1skFR ... MOQ---Euro version
https://mega.nz/file/2WpwwATR#vJaoFrmWB ... --Non-Euro version
Myrkgard
Wed Jan 06, 2021 9:28 am
can you try to flash the product (...) ?
No. When will this get fixed OTA? This is already the second brand new device that doesn't work correctly, after I had to return the first one.
Thu Jan 07, 2021 9:22 am
Hello, The OTA has updated. The last answer is the new update and please follow the step or you can contact the after-sale department directly, here is the email: support02@blackview.hk.
