benlevi.ben
usb not working
Sat Nov 07, 2020 10:58 am
hello
I have 2 problems:
I have a problem with the USB connection when I connect the device to the computer, the computer does not see the device at all
And I also have a problem with the USB OTG connection the device does not recognize the connection at all
Re: usb not working
Mon Nov 09, 2020 6:33 am
benlevi.ben wrote:
hello
I have 2 problems:
Hello, can you use another USB to try again?
Zoe Lin
Re: usb not working
Mon Nov 09, 2020 10:26 am
Perhaps ,the file transfer function of the phone is not turned on in the settings.
benlevi.ben
Re: usb not working
Mon Nov 16, 2020 4:36 pm
Where do you change that?
benlevi.ben
Re: usb not working
Mon Nov 16, 2020 4:44 pm
blackview_admin wrote:
benlevi.ben wrote:
hello
I have 2 problems:
It does not work at all, I am trying to connect another device with the same cable and it does work, can you use another USB to try again?
Zoe Lin
Re: usb not working
Tue Nov 17, 2020 10:24 am
Setting--file transfer
benlevi.ben
Re: usb not working
Sat Nov 21, 2020 10:53 am
I cant find it
Zoe Lin
Re: usb not working
Fri Dec 04, 2020 10:57 am
Asking the after sale personnel,[color=var(--blue-link)]support02@blackview.hk[/color]???
Users browsing this forum: No registered users and 10 guests
