Flavio Guerreiro
Re: Latest update BIG problem
Sat Nov 07, 2020 8:59 pm
hristovski wrote:
I just updated my Blackview A80 Pro phone (Android 9) with latest firmware: A80Pro_EEA_M557B_V1.1_20200924V14_20200924-1402
Now I have a big problem. Whenever I click a widget (on the main screen) the phone freezes and restarts! Starting the same application from it's app icon works fine for some time and then freezes and restarts again.
Holding the power button to turn off phone gets stuck for some time and restarts. I can't even restart the phone and I'm unable to use it at all now.
I even reset it to factory defaults... It froze and restarted during the setup wizard starting the phone for the first time.  :(
P.S In the end, I had to flash it back to previous version: EU_A80Pro_EEA_M557B_V1.0_20191212V08:x
I'm having the same problem, but my device is a 9900 Pro.
Flavio Guerreiro
Sat Nov 07, 2020 9:01 pm
I have the same problem in my BV 9900 Pro.
Laurenzo
Sun Nov 08, 2020 2:45 pm
Hello, do you have the link for download this rom
, Thanks.
Mon Nov 09, 2020 3:49 am
, Thanks.
Here is the link: https://mega.nz/file/jC4TUAAK#V6n2KEWUYACEL1_XyedWHV0Z6FLUuLcH7ONvQ7cgTNk
This version: m557b-dk-dk017-a2-66-512g32g-hdp-bom5-p0-cts-EU_A80Pro_EEA_M557B_V1.1_20200528V11_user_20200528.tar.gz(9.0)
Mon Nov 09, 2020 3:52 am
Hello, May I know which version do you have?  if your version is 9.0, you need to refresh to 10. if it is 10, you need to update the OTA over-the-air upgrade.
Laurenzo
Mon Nov 09, 2020 9:12 am
Can we have the link for the last version Android 10 for A80 pro ?
Thanks
hristovski
Thu Nov 12, 2020 5:48 pm
Hey,
I can't see some of my posts...
Are they deleted, or something else happened?
Laurenzo
Thu Nov 12, 2020 8:50 pm
Yes me to .....
I post a question :
Can we have a link for download the last Rom Android 10 for A80 Pro ??
Thanks
Fri Nov 13, 2020 4:05 am
Laurenzo wrote:
Yes me to .....
I post a question :
Thanks
Hello, we don't suggest to update to Android 10, please notice our annoucement.
