rkowicki
A80 Pro, SIM Toolkit compatibility, and com.android.phone error
Thu May 07, 2020 12:01 am
Three Issues
1)  Is the A80 Pro compatible with AT&T networks in 4G?
2)  If so, I'm only connecting enough to phone and WiFi.  No wireless data.
     Further issues occurred when I looked at the APN and WiFi calling settings.  I was greeted by the com.android.phone has stopped error message.
     Turning off phone services permitted me access to the APN settings.
     I did my research on the error and did the basic things advised (cleaned caches, rebooted/restarted the phone, turned off Google Play auto-update).
     The problem feels like android issue (clashing between settings program and "phone services")...and idea of how to fix that?
3)  I tried and failed to use the included app "SIM Toolkit" (I'm told that "SIM Toolkit is not ready or unsupported").  Any fix for that?
Re: A80 Pro, SIM Toolkit compatibility, and com.android.phone error
Thu May 07, 2020 3:45 am
rkowicki wrote:
Three Issues
Hello, sorry to make this inconvenience. You've better to contact our professional after-sale department: support02@blackview.hk
