bolder_toss
Smart watch Bluetooth connection lost
Thu Mar 19, 2020 11:30 am
Gday. I can't connect my {Samsung Galaxy watch active 2}
with my new bv9900
but when I use my bv9500 (not pro ver.) all works great ly fine.
also when I use bv9900 very first time, I have connected with watch without any problems, then ,after a few couples of hovers (bout 5 of less) connection lost , and don't return. none mamualu non automatically.
-many times I reset both of ma gadgets (cellphone an watch). it doesn't help .
-set battery optimisation [off]. doesn't help also.
I really love my new phone bv9900, please help good people.
Re: Smart watch Bluetooth connection lost
Thu Apr 23, 2020 6:05 am
Weaving wrote:
I have same problem with mi band 4.
Hello, what problems? Can you describe it clearly?
Khalil
Sun May 31, 2020 3:20 am
I am having the same problem.
I have connected my Galaxy S3 smart watch to the BV9900 when I first set up the phone. Everything worked great.
I switched back to my Galaxy phone temporarily and reconnected my S3 watch to the Galaxy phone, but after that I was unable to reconnect the S3 watch to the BV9900 no matter what I try.
I did a factory reset on the watch several times, I Uninstaller and reinstalled the Gear app and S plugin several times without luck.
If I try to connect the S3 to my Galaxy phone, it works the first time every time.
Mon Jun 01, 2020 7:10 am
Khalil wrote:
Hello, You'd better contact the professional after-sale department: support02@blackview.hk
Weaving
Fri Jun 05, 2020 8:10 am
Same problem with mi band 4
Bogdandqz
Where is Administration bbs.blackview.hk ??
Fri Jun 05, 2020 9:21 am
Where is moderator??
It is important.
Regards.
chammerbeck
Thu Jun 25, 2020 2:53 pm
Same here, was working before and now it no longer works.  I have a Samsung S3 Frontier watch.  I have factory
reset the watch multiple times.  I also made sure to unpair the bluetooth on both devices.  This needs to be
fixed asap.
Sun Jun 28, 2020 8:14 am
fixed asap.
Hello, thank you for your feedback, I will send this feedback to our after-sale department and find a way to solve it.
Lking
Re: Bluetooth not working at all.
Tue Jun 30, 2020 10:55 pm
Hello.
I'm experiencing multiple problems with this phone including Bluetooth not working at all.
It will flash a name of another device then nothing. No paring so no connection.
I have tried everything I can find including turning off smart battery options, duraspeed.
Opening the handset boot test mode.
I ran the test and Bluetooth failed to initiate.
Please help here.
I'm adding in the additional faults in this post so they are all seen together but I will open or add to other threads as appropriate.
L.k
Next problem is the rf test failed, no registration to lte.
I have accessed the handset testing mode via the dialer. *#*#4636#*#* and lte is on and provisioned switches are all on.
The problem is now, the ims is not Registered for volte.
The device won't do a manual operator provision.
So no phonecalls in my area because our towers are all brand new 4gdigital.
The temperature sensor is out by 15 degrees.
The screen looses touch ability.
Vodafone nz say that unless Bv contact them directly to have the Bv9900 provisioned for New Zealand the phone is not usable on 4g in Nz.
The phone seller Rugged Phones Nz refuses to help at all.
VetteofSD
Wed Jul 01, 2020 4:27 pm
Same issue. Galaxy S3 Classic watch. Mine is a Bv9900 Pro, but exact same situation. I downloaded and setup the Gear Wearable app, Samsung Accessory Service, and Gear S Plugin. Made sure Battery Optimization was turned off and every permission was enabled for all of these. Paired right away the very first time I set the phone up. After about 30 minutes, my watch disconnected and hasn't been able to since. I reconnect via the Bluetooth settings and it will say it "connects" on the phone, but the Gear S3 and Wearable app say it isn't there. I've tried removing and reinstalling everything but it just locks up and never finishes pairing again. I tried syncing the watch to my old phone and it worked right away. The bluetooth in my Bv9900 seems to work fine with other devices, no issues connecting to my car stereo. It's some sort of software clash.
