Does the BV9800 Pro Walkie Talkie function require a cellular data signal or Wi-Fi to function?
What is the range without any data signal to communicate with other walkie talkies?
Is the frequency choice programmable with many options?
Thank you!
Bplaizier wrote:If the bv9800 doesn't have a built in walkie talkie than blackview might reconsider what they are advertising on there webstie. It sure looks like it has a walkie talkie function that doesn't require cell or wifi signal based on the "anywhere" comment; On there product page it says this:
Walkie Talkie Function, Push to Talk Anytime, Anywhere V9800 has a programmable side button to use the walkie talkie function. It gives you safe, reliable and convenient communication.
Please explain why the blackview website shows it has a walkie talkie function when in reality it you say it doesn't? The walkie talkie function is one of the reasons I was going to get this so I could use it when I was out of coverage.
Thanks,
JM ONeill wrote:It would be best to remove the misleading info or photo or ad from the product page. Walkies Talkie is important to many.
blackview_admin wrote:Chuck78 wrote:Does the BV9800 Pro Walkie Talkie function require a cellular data signal or Wi-Fi to function?
Thank you!
Hello, you can use the Walkie talkie function and you need to download an APP : Zello is the best walkie-talkie app.
