Ok.
The good, and the bad:
The good: Battery life is insane. Before I connected to a carrier, I left it connected to wifi and turned on. It ran for over a WEEK! And still had 45% battery left. Best battery, I have ever seen in a phone, by far. My old Samsung Galaxy 5s would be dead by noon whether I used it, or not.
Screen image quality is amazing.
Sound quality in calls, equally excellent.
FLIR, works well, and has enough features to be very useful.
Phone is almost indestructible. It is heavy, and solid. Best build quality I have ever seen. This phone will last forever. Most phones feel light, cheap and plasticky. This phone feels expensive. When you pick it up, you know this is no ordinary phone. This, is a Blackview. I love it.
There are NO, ADVERTS built into this phone. I left Sprint, because they kept stuffing more ads into my phone. It was intolerable. I love this phone, just because it has no advertising.
The bad:
Guys, this thing needs work.
I bought this, brand new.
For starters, what, is the difference between 9800, and 9800 PRO? NOWHERE in your sales literature, does it say. It costs an extra 100$ to buy a 9800 PRO. What extra features am I buying with my extra 100$? Doesn't say. Anywhere. Is it faster? Does it have more memory? Is the screen or camera better? I could not find out. I bought a PRO just because I wanted the best. I still do not know what makes a 9800 PRO better than a 9800.
Right out of the box, it doesn't work. I place a call, the screen goes black and stays stuck until either the call ends, or I force-restart the phone. Does not respond to screen touch, only power buttons and volume control work. Proximity calibration does not work. I tried the calibration instructions I found on this forum: No good, the screen just returns to last screen.
I cannot receive calls at all. The phone rings, the screen goes black, and locks. I cannot answer the call, or do anything until the caller gives up and hangs up and ends the call.
By browsing this forum, I discovered that, 1: I'm not the only one who has this problem, 2: Somebody discovered a workaround... apparently, you can stop the screen from going black by plugging in headphones into the 3.5mm jack. And 3: The only solution offered so far is, "email support."
I should not have to "email support" to get a brand new phone to work properly. My smashed, six year old Galaxy 5S works better than this.
There are several misspellings and mistakes in the GUI. "Night camema?" Two problems: 1: There IS no "night camema", the phone has false advertising. The night camera must be purchased separately. Second, the word "camera" is spelled, "camera" not "camema". You're supposed to have someone quality check the software package before releasing it.
Misspelled words in a technical device make it look like the device is counterfeit or fake. I thought I had bought a fake Blackview phone.
"Sim toolkit" app does not work. Try to use it, it says, "sim toolkit is not ready or unsupported" If it is unsupported, why is it in this phone?
Dual SIM slots: Whose idea was it, to design the phone, so you can have dual SIM cards, OR one SIM card and one T-flash card, but not both? If you want to use the flash card, the 2nd SIM slot capability is useless. If you actually want a 2-SIM phone, the flash memory slot is useless.
The manual: There isn't one. In-phone support is extremely limited. You have to figure out, a chinese-built phone, with no manual. You're on your own. Good luck. I hope you're technical.
Feature Toolbox: Not bad, but all of it, only works in kilometers and centimeters. I am American. We use inches and miles. There is no way to change the units for the entire device. There is no way to change the units for the Toolbox. The only place I have found where you can change units, is temperature... you can select Celsius or Fahrenheit. The rest of the phone assumes you want metric, and only metric. Unacceptable.
Voicemail: There IS no voicemail. No app, no instructions, NOTHING. I learned from a friend, that I can direct-dial the voicemail at my carrier by dialing *68. If I had not been told this, I would never have voicemail at all. I could not even do THAT, until after I found out that I can at least make calls while there is something in the headphone jack.
Verdict:
Build Quality: 10. Perfect Score. Toughest, heaviest, most awesome smartphone ever. This thing makes my old Samsung look like a cheap Kia by comparison. I didn't even know anyone MADE a phone this good till somebody showed me one. If we can get the rest of it to work, I'm in love.
Usability: 4. Poor. I had to do research, to find out how to connect by USB just to load some files onto the phone. The phone connects to PC, but stays locked until you find the controls for -how- to use the USB. Again, it should not require hours of research to find out how to use a phone. "Select USB Function: Tether, Data, USB Mass Storage, PTP," should pop up automatically when connected. It doesn't. It just sits there, leaving you wondering, why you can't put files on it, and why Windows can't look into it and see it as a drive. You have to figure it out yourself, with hours of research and experimenting, and no manual. Good luck.
Hardware: Cameras, Screen, CPU, Battery: 10. Perfect score. Pictures are crisp. Wifi, just works. 4G signal, very strong everywhere. Body and casing, almost indestructible. Very poor SIM and Tflash card slot design, other than that, this thing is amazingly well built.
Software: 4.5... Poor/Mediocre. If I want voicemail, I have to go find my own app for that. Same goes for a number of other functions. I should not have to go download apps to get the phone to function fully. I thought I was buying a fully functional, developed phone. I was wrong.
Total phone score: 7.5. The amazingly good hardware saves this phone from the junk bin. If it were not so well built, I would rate it as cheap, chinese knockoff junk due to the badly thought out software and even worse quality control. If it actually worked, out of the box, without requiring heroic measures, workarounds and research just to even make a call with it, I would rate this phone a solid 9.5+. But as it stands now, if it were put on the open consumer market and advertised alongside the Galaxy and Iphone lines, it would be a disaster, and everyone buying one would sue the maker and return the phone for something else.
I'm going to keep it, and hope we can sort out all the issues, because it is that good, IF it is fixable.
Recommendation: Blackview, hire a team of white people, Americans, educated, technical cellphone users who can spell words in English, who can catch garbled syntax and poor translations to English, and who will report what the phone does badly and get it to work properly before this phone's next release.
