Blackview88
Bv5500pro keeps closing app in sleep.
Sun Apr 19, 2020 8:30 am
I installed a parental control app on my daughters phone but it keeps stopping when the screen switches off or sleeps.
I've noticed that accessibility function that the app needs keeps switching itself off. I've tried disabling all power management for the app, but nothing helps. Is there a way to keep the app running on the background, so that I can keep her safe please?
It's running Android 9
Thank you
Re: Bv5500pro keeps closing app in sleep.
Mon Apr 20, 2020 6:26 am
Blackview88 wrote:
Thank you
Hello, You've better to contact our after-sale department: support02@blackview.hk
Email: support02@blackview.hk
finmars
Mon Apr 20, 2020 10:07 am
Bonjour,
j'ai eu le meme probleme en installant un GPS et le SAV de Blackview m a aussi repondu evasivement !!
pas tres competent je crois !!
j'ai resolu le probleme en allant dans les PARAMETRES, et MEMORY CLEANUP , j'ai tout devalidé !!
et c'est OK maintenant
tenez moi au courant
Cordialement
Pierre
sams
Mon Apr 20, 2020 1:25 pm
Try Google Family Link, I use this for all my kids' devices, works flawlessly.
Tue Apr 21, 2020 3:10 am
finmars wrote:
Bonjour,
Cordialement
Pierre
This is what happens when the cleanup feature is turned on. Just whitelist this app.
Or you can contact our professional after-sale department: support02@blackview.hk.
