melczerj
Not connect to WIFI networks where SSID transmission is disabled
Tue Jul 30, 2019 11:50 am
Hello!
There is a problem with my new phone.
My phone cannot connect to WIFI networks where SSID broadcast is disabled.
If SSID broadcast is enabled then it is connected.
Please help
Thanks
Jeno
sams
Re: Not connect to WIFI networks where SSID transmission is disabled
Wed Jul 31, 2019 10:50 pm
I have no problem with hidden SSID on that device.
Remember you need to add the network manually. Adding it automatically and then disable SSID broadcast will mostly likely not work.
