Marvin bright young
Function key fixation problem
Wed Feb 05, 2020 8:10 am
I found that the function key of BV 9700 Pro is not fixed. Just a gentle touch will cause it move a little bit. Is that normal? I'm worried that the button will fall of one day.
Re: Function key fixation problem
Fri Feb 07, 2020 4:20 am
Don't worry, this is normal.
