RudyP
A lot of problem and impossible to restore to factory setting
Sat Sep 14, 2019 10:23 am
Problem with finger print, problem for installation of app', a lot of problem and impossible to use "restore factory setting"
What is the pass to restore factory setting by using *#87# ? I can trying it perhaps?
Re: A lot of problem and impossible to restore to factory setting
Sun Sep 15, 2019 6:45 am
Settings-System-Reset option
Neville
Tue Sep 17, 2019 3:12 am
Hard reset - according to a customer - appears to go to Chinese language menu? Can Blackview check and fix please?
Tue Sep 17, 2019 10:12 am
We will fix this in next update
