Another question, still about smartphone Blackview Omega Pro : it is said that you can insert a SD card up to 64 GB, and even 128 GB on some websites.
So I've inserted a 64 GB but the phone does'nt recognize it. And if I insert a 32 GB then it's OK.
As up to 32 GB it is SDHC card and to get more than 32 GB then it becomes SDXC cards, does it mean that Omega Pro is not compatible with SDXC cards ? Or do I have a problem with my phone ?
Thanks for your reply
Shantishanti
