BV9600 Pro shipped out next month will be upgraded into Android 9.0!
Wed May 29, 2019 11:54 am
Notice! The BV9600 Pro shipped out next month will be upgraded into Android 9.0! It harnesses the power of artificial intelligence to give you more from your phone. The performance gets better over time, and it keeps things running smoother and longer.
zimzia
Re: BV9600 Pro shipped out next month will be upgraded into Android 9.0!
Wed May 29, 2019 1:29 pm
The old bv9600 pro get updates to 9 ?.
Kagawan
Wed May 29, 2019 4:31 pm
I think it is better if you tell us Android 9.0 is coming to current BV9600 Pro users..and provide the 9.0 updates here.
csewell
Thu May 30, 2019 2:49 am
I'm seeing reports of a new BV9500 Plus with Helio P70 and Android 9.0, an upgraded BV9600 Pro with Helio P70 and Android 9.0, and an upgraded BV9600 (no Pro), which has to be a mistake since there never was a plain old BV9600, just the Pro and the Plus, which was supposedly cancelled. I for one would like to see an upgraded BV9600 Pro since the design is so much better than the upcoming BV9700 (Transformers, really.  Are you targeting children?). As long as they fix the WiFi, app startup, and the fact that the battery usage usage is not available.
How about letting us know if the existing BV9600 Pro's will also get Android 9.0?
csewell
Thu May 30, 2019 6:20 pm
I see the BV9600 (No Pro) is just a BV9600 with less memory and a lower cost. I wonder why they are releasing updated versions with the 9700 and 9800 just around the corner? A BV9600 Pro with the P90 chip would be awesome, provided the problems are fixed.
lokiyo
Thu May 30, 2019 6:29 pm
When are you going to goddam approve my comments?!?!
BV6000
Sun Jun 02, 2019 11:34 am
@blackview_admin our BV9600Pro will be update to Android 9?? Can you answer to this?
hanriktan
Wed Jun 05, 2019 10:09 am
Hey
We are still waiting for answer on when are we, existing user of BV9600pro are getting our upgrades to Android 9?
Don't just keep quiet and not answering.
we deserve to know.
zimzia
Tue Jun 11, 2019 5:53 am
TACWOLF
Tue Jun 11, 2019 1:57 pm
when they release the update ???
