Dphilpott81
Bluetooth on off
Thu Sep 06, 2018 7:11 pm
I have an allcall smart watch. It connects with my bv8000 pro just fine. However when I switch off the Bluetooth on the phone the watch remains connected and continues communicating with the phone unless I restart the phone.
Re: Bluetooth on off
Thu Sep 06, 2018 11:56 pm
Are you on the Oreo ROM?
Dphilpott81
Fri Sep 07, 2018 8:00 pm
Yes the Oreo ROM 8.0
Sat Sep 08, 2018 12:56 am
ok, can anybody else confirm such behaviour with bluetooth devices?
AleP
Tue Sep 11, 2018 7:32 am
I can't confirm, but I was the same problem with Android 7 and I went to settings}localization}3dots}research}and disabler the two options that are Bluetooth and wifi high precision.
Then it worked.
Tue Sep 11, 2018 10:34 pm
Then it worked.
Thanks for your feedback ;)
AleP
Wed Sep 12, 2018 6:36 am
Then it worked.
Do you solved your problem?
belond
Wed Sep 12, 2018 8:09 am
Oreo and samsung u-flex audio are doing great. Switch off/on works normally.
AleP
Wed Sep 12, 2018 8:48 am
So admin, problem solved?
Thu Sep 13, 2018 9:35 pm
yeah, we can consider it solved.
Users browsing this forum: Google Adsense [Bot] and 2 guests
