belond
NFC problem - losing control of NFC.
Tue Sep 04, 2018 7:05 am
I've upgraded to Oreo yesterday.
After some successful tries to read NFC tag device is losing control of NFC. Switch OFF - switch ON doesn't help. Switch becomes and stay inactive. Reboot helps.
Google pay used to work normally with Nougat. NFC tags used to be read with Nougat normaly.
I'll check google pay with Oreo later.
Re: NFC problem - losing control of NFC.
Tue Sep 04, 2018 10:46 am
Can aybody else confirm such issue?
belond
Wed Sep 05, 2018 10:55 am
Tag info
belond
Mon Sep 10, 2018 7:37 am
belond
Thu Sep 13, 2018 12:01 pm
Blackview_admin, could you please specify NFC module wich is used.
Strange thing - i've encountered continious reading with tag mesioned before. This mean reading procces(and plays sound) every couple of seconds.
Thu Sep 13, 2018 9:28 pm
Just asked tech team about that ;)
bilyj
Tue Oct 09, 2018 4:38 pm
I have same problem, it happen two times. And I had to make a hard reset, for torn of NFC. But I can not repeat this problem.
Tue Oct 09, 2018 10:33 pm
If the issue isn't reproducible, it will be hard to be fixed..
