evlasok@gmail.com
Miracast on BV9000-F
Tue Apr 14, 2020 3:55 pm
Helllo.
How can I turn on the broadcast function on a wireless display or TV from my  smartphone BV9000-F Android 8.0.0 (BV_BV9000_F_V0.8_20190327 ) via WI FI (Miracast) ??
Re: Miracast on BV9000-F
Wed Apr 15, 2020 7:40 am
evlasok@gmail.com wrote:
Helllo.
There is a projection on the phone screen, and then there is a square frame in the upper right corner, click to display
evlasok@gmail.com
Thu Apr 16, 2020 1:07 pm
Helllo.
I am not found. Wher is it?
See my menu BV9000-F
Fri Apr 17, 2020 7:01 am
Helllo.
Hello, You've better contact our professional after-sale department directly,
After-sale department: support02@blackview.hk
Sentinel11
Thu Mar 04, 2021 6:30 am
I have same question and I think I can find it either.
No Miracast option both on shortcut and on the settings.
Btw how to start a new topic here?
I have another question and can't fint button to start new topic.
Thu Mar 04, 2021 6:51 am
Hello, you can describe your questions here.
Sentinel11
Thu Mar 04, 2021 8:36 am
I have been using this BV9000 F pro for 2 years, I have a lot of question regarding this phone;
1. For miracast, I mean, I can't find it either, I did typo on my previous comment, so is it available or not?
2. is the update is stop for now?, since updating to Android 8, some feature is missing, small but important like LED color choice (now is only Red or nothing)
3. I have issue with charging ability, sometimes it is fast charge (I can notice if phone off, charging animation will be blue, if phone on there is time completion estimation), but sometimes it's not working, almost not charging, is it the charging port damage or what? what is best possibility?
4. My phone rubber body is damage, I can find the "backside" rubber part replacement on the market, but can't find the screen "side" rubber part (it is attached to LCD when I got confirmation from any accessories store). Since it is too expensive for me to replace LCD (because my screen is still working properly), only to get side rubber replaced. I found a store selling the side rubber only (they detached from dead LCD) but they warn me I will have issue to detached my "working" LCD from it rubber I plan to replaced (it kinda permanent glued and will damage the LCD if we detached). So, since there is no rubber side screen part available on the market, can Blackview inform me what kinda solvent I need to detached LCD from it's frame to replace rubber??
