hugoisthatguy
liquid damage, discharging quickly and flashlight/camera now working
Thu May 09, 2019 11:20 am
I recently got beer all over my phone while at a festival, and now its battery life is about a a fourth of what it used to be, it gets really hot and the flashlight and camera aren't working anymore.
Does anyone know where the problem might be, im thinking of just disconnecting the camera, so if i do, ill Update.
Re: liquid damage, discharging quickly and flashlight/camera now working
Thu May 09, 2019 8:16 pm
Hi there!
You can find spare parts on Aliexpress and here:
https://www.blackview-store.com/collections/spare-parts
You may try to replace the charging board, this may help:
https://www.aliexpress.com/wholesale?catId=0&initiative_id=SB_20190509121617&SearchText=bv8000+pro+board
phucannguyen99
Thu May 09, 2019 11:47 pm
This is what i usually do whenever my phone drop get wet or in the water
1. First, make sure don't turn it on and try to disassemble the phone and dry it with a hair drier.
2. Then if you have uncooked rice and or alternative you should put your whole phone in it for like 3 hours.
3. Reassemble while making sure you won't leave any water behind.
This should work just keep us on updates
hugoisthatguy
Fri May 10, 2019 6:28 pm
Thanks for the reply, I just bought a new phone, The bv5500 pro.
Ill keep this one as a backup and thanks allot for taking the time to reply
