Dear,
My new BV 8000 Pro has big problem, the battery just keeps at 0 % level even after charging for long time.
Then, after the third repairing shops i went to today, the service shop said that after he has checked the battery and the IC, they are all fine, and he came to the conclusion that the problem is the software or the CPU which they can not read the battery and therefore it keeps 0 % and malfunction although the battery is full.
Could you help me out with this problem ?
Thank you
