patetsch
[SOLVED] Phone stays in Charge Mode
Tue Oct 31, 2017 11:56 am
The phone stays in charging mode even after disconnecting it from the charger. It will thus not do any power saving and the battery only lasts a day and a bit. After switching it of and on again, it exits the charging mode and the battery lasts almost twice as long.
Re: Phone stays in Charge Mode
Sat Dec 02, 2017 11:53 pm
Be sure to use the original charger and usb cable.
Update to latest firmware, do a factory reset and report back.
