nonobike
[SOLVED] Notification
Mon Oct 23, 2017 4:39 pm
hello,
I am generally satisfied with my BV8000 but I never receive notifications (mail, facebook) which is very embarrassing ...
I made updates, I made a wipe of my data, always the same problem .. can you give me a solution
i am not the only one on the forum to have this problem
Thanks
Arnaud
Re: Notification
Sat Dec 02, 2017 2:47 pm
Android Nougat is, what a news ;) , the culprit.
Just add your favourite apps to the "background task clear" whitelist to get them notified correctly.
Or just disable the "background task clear" feature.
