misha_bonch
[CLOSED] wifi in status menu, when not connected to wifi
Mon Oct 23, 2017 2:06 pm
Hello.
I have an issue with wifi sign in andorid status menu (top line of the screen).
Currently, I can see wifi sign in status menu only when WIFI is on and WIFI is connected. In such case WIFI symbol appearas, filled with white .
Howver, when WIFI is turned on, but it is not connected - there is no symbol in status menu.
This is rather inconvinient.
On my previous phone, when WIFI was on, but not connected, there was a black WIFI symbol (empty), which conviniently reminded me that WIFI is on.
That helped to turn it off, when not needed, and save the battery.
Is it possible to fix this issue?
Thanks.
Michael.
Re: wifi in status menu, when not connected to wifi
Sat Dec 02, 2017 3:51 pm
Will forward this request to the tech team.
In the mean time, just use your notification drop-down menu. The wifi icon in the notification menu will behave as you desire. ;)
Re: [TRACKED] wifi in status menu, when not connected to wifi
Thu Jan 11, 2018 9:42 pm
Sorry guys, our tech team can't fix this bug at the moment.
