ruler
[SOLVED] proximity sensor and back button - bv8000 pro
Wed Sep 27, 2017 10:26 am
Hi all,
I have just purchased a BV8000 pro smartphone, 2 days ago and I've noticed 2 problems (major I would say) for which I'm searching for a workaround.
1. the back button is very often unresponsive, sometimes I had to touch it for 3-4 times in order to have the expected response. I have tried to find a pattern for a place where's better to touch but seems that there's some kind of randomness in the functionality.
2. The proximity sensor does not work accurate, very often when in conversation the screen activates, and the call goes into hold, mute, etc from the touching of my face
Please advice for some workarounds regarding the two mentioned problems.
Thanks.
Re: proximity sensor and back button - bv8000 pro
Fri Oct 13, 2017 12:49 pm
update to the latest firmware and perform a factory reset after that.
burg3r
Wed Oct 18, 2017 4:36 pm
I hope this fixing your proximity sensor problem
viewtopic.php?f=191&t=273334
jman0
Thu Nov 09, 2017 10:27 am
ruler wrote:
Hi all,
Thanks.
I've notices that tapping the back button on the right side works almost 100% of the time. The other two buttons seem to have a wider touchable surface, and the back button seems narrower
