ciccio910
Problem with audio or perhaps non-impermeable
Sun Aug 27, 2017 10:59 am
After dipping the phone to shake it up and the headphone icon appears and I do not hear the sound anymore. I'm experiencing too many problems with this phone, at least I hope it is not due to water infiltration.
Re: Problem with audio or perhaps non-impermeable
Sun Aug 27, 2017 11:04 am
After contact with water always be sure to remove all drops from usb an jack port immediately by blowing inside.
ciccio910
Re: Problema con audio o forse non-impermeabile
Sun Aug 27, 2017 11:24 am
Le ho già provate tutte...
ciccio910
Sun Aug 27, 2017 2:02 pm
I've already tried all a reset, but nothing. My fault because in other forums, not in this, I had already read of problems of non-impermeability, it was enough for 3 seconds under a fountain ... Phone really bad!
Mikehm1971
Mon Aug 28, 2017 8:19 am
Yo tengo el mismo problema después de una inmersión a 50cm no tengo sonido, el símbolo de auricular no se desconecta, que hacer ? Ya he soplado, etc...
