Discoragno
[SOLVED] IP68 Waterproof - USB-C port protection
Thu Aug 24, 2017 7:20 pm
I've a BV8000 PRO and i work near/inside water and some other liquid like sulphureus water and moisturing.
The BV8000 PRO don't have any cap usb c protection, why? The BV 7000 PRO have a good cap protection.
I think that the moisturing can damage the usb c contact. Do you have any solution about usb c cap cover?
I've find this on the web, but i think there is a good one inside Blackview company.
Please keep me informed.
Thanks
Re: IP68 Waterproof - USB-C port protection
Thu Aug 24, 2017 8:28 pm
Many people don't liked the seals. The open ports should be waterproof, just be sure to clean it from water before inserting a usb/jack-plug (simple blow inside). If you don't like that feel free to use the shown seals.
