Pappmann
Notification LED too dark
Tue Jul 11, 2017 8:21 pm
after using BV6000 im now owner of a BV8000pro and im very happy that it have finally a notification LED, but the brightness is much too low at daylight.
Is there any way to increase the brightness? Otherwise this LED is useless.
Thx
Zeerch
Re: Notification LED too dark
Fri Jul 21, 2017 12:26 am
Pappmann,
no there is no way. its not in the engineer mode to config that. so its the depth of the led in the device. someone designed and tested this phone in a dark room. maybe they can adjust it in the next ROM to increase the intensity of the led.
