aaron
black line across screen after blinking
Tue Jul 18, 2017 2:20 am
Hi, Ive had my phone for one week and the lower half of the screen started blinking , when it stopped there is now a black line across the screen that wont go away. I factory reset and still its there. is this hardware or software issue as the seller says it is a software issue. running version bv7000 pro 20170224
Re: black line across screen after blinking
Tue Jul 18, 2017 6:28 am
Please find the below flash rom to fix the screen blink problem.
viewtopic.php?f=176&t=191529
aaron
Tue Jul 18, 2017 6:52 am
the blinking stopped after a factory reset, but the line wont go away. how do I remove it? is it even possible?
Wed Jul 19, 2017 11:52 am
please post a photo of that line
