Holefighter
Stockrom flash?
Sun Jun 18, 2017 6:53 pm
Hi, is it possible to flash bv7000pro with a stock Rom?
Re: Stockrom flash?
Mon Jun 19, 2017 8:44 am
Yes, that is possible!
Here is the flashing guide: viewtopic.php?f=176&t=141026&p=322236#p322236
...and here the latest Stock ROM: viewtopic.php?f=176&t=134354
Holefighter
Re: Stockrom flash?
Mon Jun 19, 2017 9:05 am
Sorry but i want to flash a stock Android and not the BV version
Re: Stockrom flash?
Mon Jun 19, 2017 9:14 am
I fear that is not possible without special knowledge because Stock Android must be adjusted to work with each phones hardware. We have no hardware adjusted version available looking like stock android.
Holefighter
Re: Stockrom flash?
Mon Jun 19, 2017 9:29 am
OK, can you say when we geht Android 7 Rom? You said last week...
Re: Stockrom flash?
Mon Jun 19, 2017 9:44 am
I am sorry, I can tell you no specific date. We must wait to get it from the Software developers and if we find any significant bugs in the last tests it needs some time to fix them before publish.
Holefighter
Re: Stockrom flash?
Mon Jun 19, 2017 9:50 am
OK thats good
Re: Stockrom flash?
Thu Jun 22, 2017 12:06 pm
Holefighter wrote:
OK thats good
Thanks for your patience!
