@admin:
I already opened a post named "My blackview BV7000Pro do not work on Trinidad and Tobago"
My friend who buyed other Blackview BV7000Pro, that's was working fine until now, have now same problem I described on my previous post.
The phone is able to make or recieve only one call, after that, it's blocked until reeset the phone (or power cicle), or change SIM 1 to SIM 2, then when phone return back to SIM 1, it is able to make or receive other call.
The problem appeared after perform the update (The phone asked that), then it is possible more phones have same problem with this update.
It is a nice phone, but if this kind of problems are not properly fixed, there are no way to recommend the phone.
On my company, it was 12 partners ready to order BV7000Pro, but they saw the phone problems, and they reconsidered the option.
If the problems will solved properly, may be two ot three people order same phone, but not all of them.
Luis Possamay
luis.possamay@hotmail.com
