cheucheu
BV7000 PRO 4G LTE with orange France ?
Mon May 01, 2017 9:34 pm
Hi
After selected my 4G Network ( Orange France 4G), the 4G LTE is found but reswitch quickly on the 3G Network.
I'm sure my area is covered on the 4G network.
To reproduce, i switch off the WIFI , i activate mobile data and i run a search mobile networks.
Could you garantee that your mobile is compatible on the 4G of my operator?
android 6.0
Moly LR11 W1603 MP MPV27.P59.2017/03/24
Build BV7000_PRO_Blackview_20170324
BR
Re: BV7000 PRO 4G LTE with orange France ?
Tue May 02, 2017 3:25 am
Hello friend, there is something about the frequency, you can check the BV7000 pro frequency range in the below link.
http://www.blackview.hk/blackview-176/
cheucheu
Mon May 08, 2017 9:55 pm
Hi
It's OK now after upgrade.
BR
Tue May 09, 2017 5:39 am
cheucheu wrote:
Hi
BR
That's good, thanks for your information.
