nerzuhl
Battery draining fix
Fri Jun 02, 2017 8:13 am
Ok i know for many battery life is not enough on the R6 but there is a thing called "Network Location" it sucks battery way too much and thats the battery power going on and not allowing the phone to deep sleep( doze). So quick fix- download Greenify from play store and add network location to the hibernating services and press the Zzz button. It emideately will suspend the service. Also enable aggresive Doze( experimental) in the options . And now that you had battery that last barely 2 days in standby mode will now last ~7 days! I recently charged the phone so cant post screen to proove you this but try and you will be amazed
Athomik
Re: Battery draining fix
Sat Jun 17, 2017 5:10 pm
Hi i can confirm also it's working good job finding the problem now it's Blackview time to fix it quick ... And we still need a solution for the uncommon lag the phone has while in games wich shouldn't happen
strummer
Thu Aug 03, 2017 2:58 pm
Thanx a lot for advice.......
strummer
Wed Aug 09, 2017 12:26 pm
Never worked for me.
In truth the battery is terrible !!
