zebu
Speaker volume problem
Mon Oct 17, 2016 9:13 am
I have a problem with my bv6000.
The speaker (rear loudspeaker) sound is very low so I can't hear it ringing when in my pocket for example or watching videos is difficult.
He has always been very low.
If I blow some air with my mouth in the phone case, the sound gets louder for some seconds/minutes and then gets back to a low volume.
It seems to be a hardware problem...
Re: Speaker volume problem
Tue Oct 18, 2016 3:31 am
first kindly tell you that the problem about bv6000 should be posted on the BV6000 board, this one is for BV6000S.
And for the speak problem you refers to , please contact your seller for repair.
