maho88
Two camera problems
Fri Feb 03, 2017 10:39 am
I have the BV6000 running Android 6.0 BV6000_Blackview_V01_201600922. I have two camera problems:
1) The camera app is stuck on the front facing camera- no way to switch to the rear facing camera.
2) When holding the phone in portrait mode, the image in the camera is upside down.
Any help or advice appreciated.
Re: Two camera problems
Sat Feb 04, 2017 3:32 am
It may be a problem about the camera.
You need to contact the seller for repair.
benja
Tue Feb 14, 2017 6:04 pm
hello, I have a BV6000 and camara dos'nt work. When i do click on it it goes on a black screen for two seconds and the back to the house screen. I already reestarted a couple of times but, nothing happen. There is any problems with that? any solutions? thanks for your time
