Dear Sir /Madam
I have just purchased a BV6000s. Two problems. Android pay doesn't work - it reports " Android Pay can't be used with this device - This may be because your device is rooted, has an unlocked bootloader or is running a custom ROM. As a result, Google can't confirm that your device meets Android Pay's security standards."
The second problem is with the length of time it takes to charge the device - it is painfully slow.
Thanks,
Goth
