dale
Bluetooth
Fri Mar 10, 2017 9:51 am
I received the new Android Update to my BV6000.
Rom version: BV6000_Blackview_V01_20170223
After this update I noticed that the battery is getting eaten up like crazy.
I've noticed that when I lock the phone the bluetooth is getting enabled.
The battery life indicator shows that it's using over 40% of the battery.
Is there any way to disable Bluetooth permanently or any other way to get this fixed?
Cheers,
Dale.
Re: Bluetooth
Sat Mar 11, 2017 6:04 am
Can you please tell your location?
dale
Re: Bluetooth
Wed Mar 15, 2017 11:12 am
Poland
k1sa
Re: Bluetooth
Fri Mar 17, 2017 7:06 pm
Hi! I have same bug too. I am from Latvia.
bvsweden
Re: Bluetooth
Mon Mar 20, 2017 8:55 am
dale wrote:
I got the same problem with my BV6000 after this update.
Not that location got anything to do with this s/w issue but I reside in Sweden.
Janne
Re: Bluetooth
Fri Mar 31, 2017 5:30 pm
Hello
I have the same problem with mine. Version V01 20170223. It will connect, and then after 30 sec it will loose the connection. Then re-connect and then the same. What is the problem? I see an app under system called BT-tool, haven't seen it on another android unit before.
dale
Re: Bluetooth
Sun Apr 09, 2017 4:59 pm
Poland.
