Sapto Harsoyo
WhatsApp has error connection after wireless update
Tue Jul 12, 2016 3:18 am
My name is Sapto, I have facing problem after update the wireless, the problem is WhatsApp messenger not connected.
The WhatsApp can connect after the device power on and restart, but only for short time.
I already reinstalled the WhatsApp, even my device was reset factory, but the problem still happen.
Any body can help me.
Thanks
Re: WhatsApp has error connection after wireless update
Thu Jul 14, 2016 3:33 am
What's the verison of your firmware?
Best regards,
Admin
Sapto Harsoyo
Thu Jul 14, 2016 5:12 am
V01_20160630
motecma
Thu Jul 14, 2016 6:11 am
Hi, I have de same problem.
Since I installed the latest update , Whatsapp lose the connection and does not send or receive messages until it is restarted. Please, review it.
My versión is V01_20160630
Regards
dabomb
Thu Jul 14, 2016 7:39 am
dabomb wrote:
I'*m now going to deactivate the "Background Task Clear" in the settings section. Maybe this will help us out. :roll:
This should help you.
Sapto Harsoyo
Thu Jul 14, 2016 8:40 am
Thank you "dabomb" for your suggestion, I will try it then immediately inform to you.
Admin, I also already update about firmware. Now I am using V01_20160704 firmware version, but WhatsApp still not connected after 1 hour.
Fri Jul 15, 2016 9:39 am
Regards
It is one installed via local upate ?
Best regards,
Admin
Sapto Harsoyo
Sat Jul 16, 2016 2:11 am
Hi All,
Firstly I want to say thank you very much to "dabomb", after deactivated "Background Task Clear" my WhatsApp become works normally.
So, for all my friends that who have same problem with me " WhatsApp error connection", please follow "dabomb" suggestion.
Admin, I update the firmware via local update, follow your suggestion.
Fainalsyam
Thu Jul 21, 2016 9:59 pm
Thanks dabomb .. it works..
