Don Harry
New update 2017 07 08 availible
Fri Jul 14, 2017 2:29 pm
New update 20170708 availible
bvbw
Re: New update 2017 07 08 availible
Fri Jul 14, 2017 3:09 pm
Yes, but see this topic : viewtopic.php?f=144&t=178175&start=10
Maybe it's better to wait before upgrade ...
The_Saint
Fri Jul 14, 2017 3:44 pm
I have updated to V01_20170708 and then factory reset as I always do after every single update. A bit time consuming, but with google account it is more simple.
- glove mode is still deactivated
- problem of sleepy right soft key "back" in my phone is gone
Maybe later I can say a bit more.
bvbw
Fri Jul 14, 2017 4:16 pm
What is your build number after update ?
The_Saint
Fri Jul 14, 2017 4:28 pm
As per CPU X following information:
Build ID: NRD90M
Build time: 08-07-2017 07:39:52
As per wireless update only one information:
Current: V01_20170708
bvbw
Fri Jul 14, 2017 4:35 pm
Means they use an old ROM without working seriously on the bugs ...
Seems the end of support of this device ... Hope i'm wrong !
The_Saint
Fri Jul 14, 2017 4:39 pm
I suppose you are right, because of focusing on new models. Blackview, so pity...
onsirt
Fri Jul 14, 2017 4:54 pm
Hello admin,
I hope left capacitive button (menu) that now have function "recent apps"
in the next update can be turn back to "MENU" AGAIN, NOT "RECENT APPS"
thanks.
h0w4rd
Wed Jul 19, 2017 7:56 pm
This is how it should be :
Menu button - short press - context menu
Menu button - long press - google assistant
Home button - short press - home launcher
Home button - long press - app switching
Why have you changed it?
Esko
Thu Jul 20, 2017 9:20 am
I'm very thankfull, because OTA updates started to work for my phone.
The traslation to Finnish language according update process is guite poor but it doesn't matter.
I have the latest update 20170708 now installed and everything seems to work well.
I'm satisfyed with the new features and changes.
The added Google apps can be disabled if someone wants to do so.
Good work again Blackview Team!
Best Regards
Esko :D
