Jonny Jager
BV6000 wont charge anymore !!
Wed Sep 21, 2016 5:50 am
Sinds yesterday my BV6000 went dead after i plugged it into my pc for some foto exchange.
IT stays at 0% witch charging even wen i charge it 12 hours . and my touchscreen doesnt react anymore.
Already tried a hard reset . Please help or how does it work with the warrenty ?
Re: BV6000 wont charge anymore !!
Wed Sep 21, 2016 6:16 am
Jonny Jager wrote:
just the touchscreen can not react ? the phone can power on /off ?
And you charge it 12 hours with the standard charger?
Pappmann
Wed Sep 21, 2016 2:12 pm
i had same problem, the reason was a broken solder on the usb connector.
ubuntolaio
Thu Sep 22, 2016 2:04 pm
me too. Dead phone after reaching . Maybe the soldering isn't good enough
Jonny Jager
Fri Sep 23, 2016 5:01 am
hello papman,
was this easy to fix can you explain me how you did this ?
do you have a picture ?
greets Jonny
Mon Sep 26, 2016 6:29 am
Pappmann wrote:
if it meet the warranty itme , you can contact your seller for repair.
