SnuffThePunkz
Speaker has halfed volume
Wed Sep 07, 2016 4:07 pm
Hey so love the phone, much like the bv5000 I had.
But the rear speaker has started to fail, it used to be loud and somewhat clear (water proof so never 100% clear I know). Now it at best works at half volume, I can't hear it ringing if it's in my pocket, or I'm driving (not the worst thing), or I'm working. Can't even listen to music or watch videos through it in a slightly noisy environment.
Ear speaker for calls works, headphone jack works as does Bluetooth audio so it took me a while to notice it not being as good as it was.
I would prefer not to return it to the online seller for a fix/replacement, as that will have me without a phone for 2+ months. Is there someone that sells parts like they did for the bv5000?
SnuffThePunkz
Re: Speaker has halfed volume
Wed Sep 07, 2016 4:13 pm
Well I found a retailer on AliExpress that sells the rear cover with the speaker, so I guess that sorts that out.
Blackview BV6000 Battery Cover + Loud Speaker 100% Original Official Back Case Replacement Accessory For Blackview BV6000S
http://s.aliexpress.com/rA7BviMj
(from AliExpress Android)
