alexk
lost gps connect again and again
Mon Sep 05, 2016 9:30 pm
i'm here in Germany and can't use the bv6000 gps with an an navigation app. Every 2-5 minutes it lost gps connection.
With my Samsung Ace II i had no problems.
Testing with Android App "GPS Test"
The bv6000 has 10 satellit with an signal strength of 16-23
The Samsung ACE II has 11 sattelit with an signal strength of 25-38
are there any settings i can change on the bv6000 to improve?
Re: lost gps connect again and again
Tue Sep 06, 2016 8:38 am
Try a firmware update.
Best regards,
Admin
alexk
Thu Sep 08, 2016 8:02 pm
the phone is currently on BV6000_Blackview_V01_20160822, but gps is not usable
is there a newer firmware with better gps support?
akippar
Fri Sep 09, 2016 6:27 am
akippar
This is already the latest version.
The reason causing the GPS lost is various.
Maybe a weak signal. you can try it in some open areas to see if it still fails to work properly.
Derk
Fri Sep 09, 2016 5:38 pm
I'm using the same ROM release and even when in my house I get an accuracy of 5 m and a time to log into position of unter 1 minute.
Try the App "GPS Test", it shows you exactly which satelites the phone sees and connects to.
This might help finding your issue.
mctimo
Mon Sep 12, 2016 2:53 pm
I also have a weak gps signal after the last update i think. In my car it dont work anymore.
How can i fix this?
Tue Sep 13, 2016 5:53 am
How can i fix this?
Yours now is also of 20160822 version ?
Best regards,
Admin
mctimo
Sat Sep 17, 2016 8:07 pm
Yes i got the latest firmware
