BVWarrior
No MMS even in safe mode
Tue Jul 26, 2016 2:17 am
BV6000 is great so far except I cannot receive or send MMS. All settings are confirmed but it does not work. Is this the Marshmallow 6.0 bug I've heard about? Will Black update to 6.0.1 to solve this? Please help...
Re: No MMS even in safe mode
Tue Jul 26, 2016 6:09 am
what is firmware version in your device ?
Best regards,
Admin
6000 user
Tue Jul 26, 2016 6:40 am
MMS work for me on original firmware. I had to manually change some settings because service provider info was not OK. You have to manually change those settings on lots of phones.
Go to: SETTINGS->Wireless&networks->More->Cellular network settings->Access Point Names
Your cell service provider probably has online tutorial to change those settings. They are for more popular phones but settings are the same. Different android versions have different but similar menu options.
