Pappmann
How to disable Speaker noise?
Thu Jul 14, 2016 1:17 pm
the BV6000 have problems with Speaker noise, when some Apps are open. The noise is strongest, when phone is connected via GSM.
Is there a possibility to shield the Speaker module?
In the following Video u can see that the Speaker module is at the bottom of the phone:
https://youtu.be/9yLEemeXFnY
Re: How to disable Speaker noise?
Fri Jul 15, 2016 9:28 am
Pappmann wrote:
which app you have tested it on ?
Best regards,
Admin
