SnuffThePunkz
Dear Blackview Admin
Wed Jun 08, 2016 7:06 am
You are the only real person at Blackview I've had any real dealing with so I'm reaching out to you with my question.
Due to a dumb move on my part I shattered the screen on my BV5000 which despite the radio issues, the OS 6.0 that fixed the radio issues, but wouldn't allow charging, etc. I Love. So about the BV6000, before I spend $70 on a new screen I have some questions.
1. The radio. Are the bands advertised tested and accurate this time? Not like the BV5000 that had ranges advertised where people bought it and showed that it was falsely represented. Then the product page on the Blackview website changed days later to represent the users findings?
2. Is it the same radio that was used in the BV5000? Or is it a new one?
3. The Glass. Is it stronger? The drop of my phone was spectacular, and without a otter box or rugged case, no other phone I've owned would have survived so I'm not upset. But a lot of upset users are from small drops that should not have done any significant damage.
I don't mind throwing my hat in the ring with you guys again. For all the troubles it's probably my second favorite phone I've ever owned, and the BV6000 looks like it could be better. But I need these questions answered if you could.
Re: Dear Blackview Admin
Wed Jun 08, 2016 7:38 am
1) For test we done for BV6000 is real and actual. it is really a very tough tri-proof device.
2) For the radio , could you tell me what is your meaning by asking if is different from BV5000 ? (i am not so clear about what u refer to )
3) For glass , we have done some relative tests, do not worry, really really a strong one because of its design and Gorilla Glass 3 material , it is
very hard to broke it.
You will never regret to buy this one. Hope my answer can help you. Thanks a lot!
Best regards,
Admin
SnuffThePunkz
Thu Jun 09, 2016 2:40 am
In regards to the radio. Is it the same physical cellular radio (That connects to the cellular network) that was in the BV5000 such as the same model, or has it been replaced with a new one?
And the glass looks much more recessed instead of protruding like the BV5000.
I've gotten in touch with my retailer about it.
